  1. hello good day, I have the following problem:
    when I try to encode a video from mkv to mp4 by adding 2 subtitles to the video, as follow:
    LoadPlugin("C:\Program Files (x86)\MeGUI-2808-32\tools\avs\plugins\directshowsource.dll")
    DirectShowSource("E:\Tv Show\Reasonable Doubt\07\reasonable.doubt.2022.s01e07.1080p.web.h264-glhf.mkv", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001)
    #deinterlace
    #crop
    #resize
    #denoise
    LoadPlugin("C:\Program Files (x86)\MeGUI-2808-32\tools\avisynth_plugin\VSFilter.dll")
    TextSub("E:\Tv Show\Reasonable Doubt\07\Reasonable Doubt (2022) 1x07.srt", 1)
    TextSub("E:\logo.ass", 1)
    That way megui doesn't allow me to encode from mkv to mp4 and i get the following message:
    [Attachment 67446 - Click to enlarge]
    Here some error log of those jobs:
    [Error] Log for job2 (video, reasonable.doubt.2022.s01e07.1080p.web.h264-glhf.avs -> )
    -[Information] [11/2/2022 1:47:03 PM] Started handling job
    -[Information] [11/2/2022 1:47:03 PM] Preprocessing
    --[Information] Bitrate calculation for video
    ---[Information] [11/2/2022 1:47:04 PM] Desired size after subtracting audio: 367742 KBs
    ---[Information] [11/2/2022 1:47:04 PM] Calculated desired bitrate: 984 kbit/s
    -[Information] [11/2/2022 1:47:04 PM] AviSynth input script
    --[NoImage] LoadPlugin("C:\Program Files (x86)\MeGUI-2808-32\tools\avs\plugins\directshowsource.dll")
    --[NoImage] DirectShowSource("E:\Tv Show\Reasonable Doubt\07\reasonable.doubt.2022.s01e07.1080p.web.h264-glhf.mkv", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001)
    --[NoImage] #deinterlace
    --[NoImage] #crop
    --[NoImage] #resize
    --[NoImage] #denoise
    --[NoImage] LoadPlugin("C:\Program Files (x86)\MeGUI-2808-32\tools\avisynth_plugin\VSFilter.dll")
    --[NoImage] TextSub("E:\Tv Show\Reasonable Doubt\07\Reasonable Doubt (2022) 1x07.srt", 1)
    --[NoImage] TextSub("E:\logo.ass", 1)
    -[Information] [11/2/2022 1:47:04 PM] resolution: 1920x1080
    -[Information] [11/2/2022 1:47:04 PM] frame rate: 24000/1001
    -[Information] [11/2/2022 1:47:04 PM] frames: 73402
    -[Information] [11/2/2022 1:47:04 PM] aspect ratio (avs): 16:9 (1.778)
    -[Information] [11/2/2022 1:47:04 PM] Job command line: "C:\Program Files (x86)\MeGUI-2808-32\tools\x264\x264.exe" --pass 1 --bitrate 984 --stats "E:\Tv Show\Reasonable Doubt\07\reasonable.doubt.2022.s01e07.1080p.web.h264-glhf.stats" --keyint 240 --sar 1:1 --output NUL "E:\Tv Show\Reasonable Doubt\07\reasonable.doubt.2022.s01e07.1080p.web.h264-glhf.avs"
    -[Information] [11/2/2022 1:47:04 PM] Process started
    -[Information] [11/2/2022 1:47:04 PM] Standard output stream
    -[Information] [11/2/2022 1:47:04 PM] Standard error stream
    --[Information] [11/2/2022 1:47:05 PM] avs [info]: 1920x1080p 1:1 @ 24000/1001 fps (cfr)
    --[Information] [11/2/2022 1:47:05 PM] x264 [info]: using SAR=1/1
    --[Information] [11/2/2022 1:47:05 PM] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
    --[Information] [11/2/2022 1:47:05 PM] x264 [info]: profile Main, level 4.0
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: frame I:833   Avg QP:18.80  size: 53846
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: frame P:20766 Avg QP:22.33  size: 10504
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: frame B:51803 Avg QP:24.53  size:  2020
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: consecutive B-frames:  2.2%  6.6% 13.0% 78.1%
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: mb I  I16..4: 74.0%  0.0% 26.0%
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: mb P  I16..4: 14.4%  0.0%  0.0%  P16..4: 21.8%  0.0%  0.0%  0.0%  0.0%    skip:63.8%
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: mb B  I16..4:  1.1%  0.0%  0.0%  B16..8:  6.4%  0.0%  0.0%  direct: 2.8%  skip:89.7%  L0:41.7% L1:52.3% BI: 6.0%
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: final ratefactor: 25.57
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: coded y,uvDC,uvAC intra: 12.7% 30.3% 3.8% inter: 1.4% 4.1% 0.0%
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: i16 v,h,dc,p: 45% 28% 15% 12%
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 21% 18%  7%  7%  6%  6%  6%  4%
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: i8c dc,h,v,p: 59% 20% 19%  2%
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: Weighted P-Frames: Y:0.5% UV:0.2%
    --[Information] [11/2/2022 2:04:07 PM] x264 [info]: kb/s:960.63
    --[Information] [11/2/2022 2:04:07 PM] encoded 73402 frames, 136.24 fps, 960.63 kb/s
    -[Error] [11/2/2022 2:04:07 PM] Process exits with error: 3
    -[Information] [11/2/2022 2:04:07 PM] Job completed
    -[Information] [11/2/2022 1:10:43 PM] Started handling job
    -[Information] [11/2/2022 1:10:43 PM] Preprocessing
    ---[Information] [11/2/2022 1:10:43 PM] Desired size after subtracting audio: 367742 KBs
    ---[Information] [11/2/2022 1:10:43 PM] Calculated desired bitrate: 984 kbit/s
    -[Information] [11/2/2022 1:10:43 PM] AviSynth input script
    --[NoImage] #crop
    --[NoImage] #resize
    -[Information] [11/2/2022 1:10:43 PM] resolution: 1920x1080
    -[Information] [11/2/2022 1:10:43 PM] frame rate: 24000/1001
    -[Information] [11/2/2022 1:10:43 PM] frames: 73402
    -[Information] [11/2/2022 1:10:43 PM] aspect ratio (avs): 16:9 (1.778)
    -[Information] [11/2/2022 1:10:44 PM] Job command line: "C:\Program Files (x86)\MeGUI-2808-32\tools\x264\x264.exe" --pass 1 --bitrate 984 --stats "E:\Tv Show\Reasonable Doubt\07\reasonable.doubt.2022.s01e07.1080p.web.h264-glhf.stats" --keyint 240 --sar 1:1 --output NUL "E:\Tv Show\Reasonable Doubt\07\reasonable.doubt.2022.s01e07.1080p.web.h264-glhf.avs"
    -[Information] [11/2/2022 1:10:44 PM] Process started
    -[Information] [11/2/2022 1:10:44 PM] Standard output stream
    -[Information] [11/2/2022 1:10:44 PM] Standard error stream
    --[Information] [11/2/2022 1:10:45 PM] avs [info]: 1920x1080p 1:1 @ 24000/1001 fps (cfr)
    --[Information] [11/2/2022 1:10:45 PM] x264 [info]: using SAR=1/1
    --[Information] [11/2/2022 1:10:45 PM] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
    --[Information] [11/2/2022 1:10:45 PM] x264 [info]: profile Main, level 4.0
    -[Error] [11/2/2022 1:22:36 PM] Process exits with error: 0xC0000409 STATUS_STACK_BUFFER_OVERRUN (-1073740791)
    -[Information] [11/2/2022 1:22:36 PM] Job completed
    But for example if I only encode with 1 subtitle the video successfully converts from mkv to mp4.
    I have returned to work with megui after many years, in the past I encoded the way I am trying now and I did it very well, now I don't know if I am forgetting to configure or install something to be able to encode that way.
    I hope you can help me and see together where the cause of the error could be.
    Mar 2008
    Directshowsource is not recommended, try Lsmash/LWLibavVideoSource or FFvideosource.
    First, open your script as-is in Virtualdub2, set the video/compression and see if it works there
  3. You could also remux only your mkv to mp4, without recoding, and add your subtitles with clever FFmpeg-GUI.
    [Attachment 67452 - Click to enlarge]
